I once had a 89 2.9 that backfired ONCE as I was shifting into 2nd gear. It went dead, and never started again.
I had fire, fuel, and a clean air path. Timing was dead on and not worn or loose. No coolant leaks and perfect compression with no leaks. No broken rods, valve springs, bend vavles, or holes in the pistons. No cracks in the block, or blown head gaskets. Neither the cam nor the crank was broken. No knocks when trying to start. No cracks in the heads, or upper or lower intake. No spun main or rod bearings.
So I replaced the motor with one from an 87. Used the distributor, TFI module and EXACT same sensors and wiring from the "old" 89 motor...none of the "new" 87 motor wiring was used AT ALL! Fired right up, and has ever since.
So you tell me what may have went wrong. TO THIS DAY no one has been able to find the problem.
