Solid Front Axle Swap Poll (Whatcha got?)
What solid front axle have you swapped in?
  • Total voters
    292
Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
I wanted to see who has swapped in what by way of this poll.
Feel free to add pics if you want.
If you choose 'Other', please specify below.
I got the first one with my E.B. swap. By far the easiest. With an E.B. as a donor it is almost a bolt in. I don't have pics of the swap but, The truck is on my photobucket, sub-album "Deranged mudder".
I would love to try a set of portals (unimog) but, I have never seen a set in person, Much less had an opportunity to buy them.
Full Width D44 from an 77 F150
I've got an EBD44, and am still workin on swapping it in. It's gonna have crossover high steer running OTT style arms, with 1.75'' DOM tie rod's and Chevy 1 ton TRE's. Gears are Yukon 4.56's, still waiting for some shafts, and front is open for now, goin with an ox locker when I can afford it.
And the current sad state of affairs....both front and rear axles are now lyin in my DD awaiting rebuild, and the shop's a lil cleaner thanks to my dad...:temper: I'll have to grab some new pics of my 5.5" chevy leafs when I get a chance. :yahoo: Anyone need a detroit locked 28 spline 8.8?
-Andrew
Almost done, late 70's F-250 HP Dana 44, narrowed to waggy width, converted to 6 lug, chevy flat-tops.
not done yet, but I picked other. Waggy D44.
No pics, but I've had a full width HP D44 out of a 74 F100 for about 2 yrs now. Converted to discs using Ford outers and running 4.88 gears and a Lockright.
IMO, full width or a Waggy D44 is the way to go.
yea i think the next time i do this, it will be a full width 44. I got this axle kinda out of the blue, and once i ve done it, a fullsize isnt much harder. Im looking for a ranger that has a lift already so i dont have to deal with rivets haha. Ive also considered a fx4 level II with the waggy front, but that would be pricey right now. But man what a daily driver/weekend warrior!!
I could only vote once but i have done dana 60 with a 14bolt and 2.5 ton rockwells and probably fixing to go 5 ton if everything works out .
Is there a front axle in that picture?????
78-79 F-150 Hi pinion full width
Not done yet but I have the HP44 and 9" out of a 79 Bronco. Will go under the Ranger when I get the 302 lined out(pin holes in the cylinders of the new .060 engine, so I think I will stroke the 69 block I still have, use my "68 heads)
