SOHC problem
MSGia
Central Florida
Total Drop
5, 5
Good evening all, I have been noticing some concerning things with my ranger. On startup (cold or warm) it has a really bad creaking and ticking sound. It kinda fades off after I start driving, but when I am in high RPMs, the engine sounds extremely muffled and just horrible. Any tips on what it could be? I haven’t really seriously looked into it yet,
And also it shakes hard, harder than normal, when I turn the car off.
could be timing chain issues you can remove the driver side valve cover, or drop your oil pan. my set was done for everything was broken.
Check the fan clutch, reads like it broken/out of balance
Thanks for the replies all, I posted this on Sunday and I found out since then on a mechanic forum on Reddit. At the time there was no CEL, and I kept driving it and a few days later the noise kept getting worse, and I got code P0420, I think it’s because some of the honeycomb in the cat got loose or a leak, it smells like crap and the rattle. But I’ll definitely look into the fan clutch because I don’t know if that would explain the rough turn-off.
