SOHC 4.0 into 1st gen Ranger
Bent Bolt
Ford Technician
Solid Axle Swap
Edmonton,AB
Wasn't there someone here that installed a SOHC into 1st gen Ranger or BII ?? Just looking for info on heater box and oil pan clearance.
ya that was me. the oil pan had no issue, you just need to use the motor mounts off of the 2.9. and the air box i used the airbox from the 2004 ranger. so I had to cut the fire wall and make a new fire wall with the holes for the new one.
and here is a pick of the interor of the truck with 04 dash.
If you need more pic. I hopfully try to find some more. on the other computer.
Cool, thanks !! In your opinion would a non A/C heater box and body lift clear the SOHC ??
Can I get more pics of how you mated that dash to the interior? Did you have to weld on any tabs to screw it to the body/firewall? How about the steering wheel?
Thanks,
Ryan
..oh yeah...
There is a guy on the ExplorerForum site that has a SOHC motor running in his First Gen Explorer, with the OHV computer, and wiring...
Ryan
Thanks,
Ryan
sorry I don't have my other camera at this time. But ya I had to make tabs out of 2inch angle iron. I then riveted the brackets in and bolted the dash in. and for the steering shaft I used a shaft out of a 97 ranger. with no issue. and about the use of a non ac box. I'm not sure about. it seems that the heads are pretty wide compared to the 2.9.
