Kiba
- Dec 25, 2015
- Houston, Texas
- My credo
- Speak softly and drive a truck with a stick
Hi all. Have a '99 2.5l I4 paired with a stick, and I love it. However, there isn't much out there to tell me how to get the most from this little engine.
I come from a motorcycling background and there are usually plenty of details on where the "sweet spot" for power, economy, or engine life is, projected engine life with a certain kind of use, minimum and maximum rpm, shift points, cruising rpm, etc.
Right now I'm driving like an old man in the city; my shift points are between 1800-2200 in city traffic. On the highway I shift at 2400-2700, 3000 only if merging. Maximum cruising speed is 85 indicated (90 IRL) in overdrive, turning 2700 rpm. Also keep it in fourth up to 55 sometimes at 2600 rpm. Never had it above 3k.
So, my question is, what is the sweet spot for this motor? What's the highest cruising RPM which it can sit at for a long time without stressing the motor, what's a comfortable shift point for quick acceleration that doesn't stress the motor, etc? What's the ideal RPM for fuel economy (for reference, it's not always the lowest), both in normal gears and in overdrive?
I've seen graphs showing the power peak at 4500 rpm and the torque peak at 3000, pretty normal for a four-cylinder but I'm not sure this motor likes revs that much!
Also curious on what affect minor intake/exhaust modifications (such as a K&N type intake, slightly more open exhaust) have on the life of the motor. I'd like a little more power, and a little more exhaust noise (nothing excessive) but do not want to shorten the life of the motor at all. I want 300k out of this truck!
For reference:
Right now I have 188k on the motor, not sure of the rear-end gearing but I believe it's stock.
I have a small tachometer installed to keep track of revs when I take long trips. Tested to +/- 5% accuracy with a real shop tach.
Running the 30" tires that were on the truck when I got it, which gears it up.
GPS verified, speedometer reads five mph less than actual speed over 60mph- ie if my speedometer says 80mph, my actual speed is 85-87.
For reference:
