snythetic oil ?
joesdca
hi, i have a 2002 ranger edge with a 7.5 rear end with 4.56 gears and
a auburn limited slip installed on it i was going to change the gear oil
but i keep getting conflicting stories on what to use. i believe i was
told by a guy at auburn not to use a synthetic oil. and other knowledgeable
sources are saying you can. i use royal purple in my motor and i would
like to use a synthetic oil in the rear end as well. maybe amsoils new "severe
gear" oil. the shop i go to sold me some swepco 212 moly multi grade gear
lube to use but i am going to hold off and try to get some more feed back.
any help would be appreciated. thanks, joe
Save your pennys, your rear end won't care if its got synthetic in it or not. Just run a friction modifier for the limited slip.
go ahead and get the royal purple fluid. Get the heaviest weight for the back end tho.
Maybe it would be a good idea to contact Auburn and see what they have to say about what goes in their differentials ? I had a post similar to this a week or two ago and the differences of opinion were quite pronounced. I researched this until the cows came home and I still don't have a definitive answer.
Short answer is unless you go way off the manufacturers specs, dino or synthetic wont hurt either way. The addition of a friction modifier seems to be linked with which oil you use. Some need the addition, others don't. To further add to the confusion, I spoke with a guy who builds rears for short track racing and he said all L/S need the modifier to make the clutches work properly. Others
indicate if there is no chatter, dont put it in as it may limit the ability of some L/S to grab as they should. He uses nothing but Mystic and asked me what I wanted when he installs mine ( factory L/S ) next Wednesday.
I said I'd let him know.....
:nopityA:
thank you for the info mr ngzcaz i know what you mean everyone i
talk to tells you something different i just want to put the right stuff
in there. i have talked with aurburn once before and that person said
not to use the synthetic put he did not sound to confindent, i sent
auburn a e-mail yesterday and i might call them agian tomarrow. i
see that you mention the word "chatter" which is one of the reasons
i wanted to pull my cover and inspect my rear end. i have had a bit
of a problem with chatter when i first start up my truck and go some
where. the first couple of times i let the clutch out i get some chatter
and some times it seems to shake the whole truck. my u joints look good
and about a year ago i had a centerforce clutch and plate, ect installed
and at the same time i had the auburn limited slip installed. everything
has worked ok untill the chatter started about 6 months ago. i have about
7-8 thousand miles on the set up. in talking with the shop that did the
work i do not think they used any kind of a friction additive. anyway any
advice is really appreciated thanks, joe ps. i also installed a camburg sub
frame about the same time the chatter started.
FYI Since I too am installing a L/S this week, I started checking into different oils and their properties. As I was doing so I came across Auburns website. They recommend straight 80/90 oil with a FM. I wish I could as straight an answer from Ford. Other than universally saying add the FM no matter what, the choice of oils is wide open.
:tease::dntknw:
