Mark_88
- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
This is a bit long winded, as per my usual...lol
I've been trying to find a replacement block or complete engine due to the smoke issue. My truck must pass the emissions again next year and I've recently been pulled over for "excessive smoke" which could result in the vehicle being taken off the road.
Not having any luck so far with the scrap yards since they all disposed of anything over 98 a while ago...but there is one that can do a parts watch for me if I ask.
Anyway, here is something interesting. A mechanic friend told me a while ago to unplug the PCV and see if the engine still smoked...so, finally, today I did just that...took it for a long test run and it did not smoke at all. I did not test it under the most extreme conditions where I actually noticed the smoke and that was to take it on a long highway drive.
Apparently, deceleration is a "high vacuum" condition where the PCV or the engine can and will draw oil. If the condition happens with the pcv disconnected I can pretty much call it a day and set to rebuild the engine. If, however, this does NOT happen with the PCV disconnected then what is most likely happening is the PCV being open and a high vacuum condition being present, the vacuum will suck oil up through the bottom end and result in the cloud of smoke on deceleration...
This can also result in oil being drawn through the valve seals and give the same result.
Now, my question is, does this make sense?
And, if it does appear that my PCV is allowing too much vacuum leading to oil or oil particles to be drawn into the intake and then burned causing the smoke is there a way to actually reduce the vacuum on the PCV and limit the amount of oil being drawn into the intake?
I've been reading several different forums and going through numerous pages of information to try to determine if I need to rebuild the head, maybe re-ring or rebuild the block or both.
I will say that I am not in a position to do either currently...and that otherwise, the motor runs fine...uses too much oil...but otherwise has (or had) good compression and is strong (for a 4 banger)...
