Sludge Horor Stories
UPDATE:
I used the stuff as directed.
put it for prior to change, ran 5 min.
when I drained it, it was very BLACK!
I added this step: I drained 2/3s and filled back up with new cheap oil, and ran it for another 5 min for a extra flush.
Drained that out and very BLACK! Again.
changed filter and put new oil in.
ALL is well.
the stuff seemed to work, less engine noise, pressure unchanged.
I would do it again.
the stuff itself. when opened it had the SMELL and consistency of Diesel. wonder if the just add some detergent to a quart of diesel and call it good.
seemed to work, satisfied with results, was cheap, and most importantly it didn't make things worse :icon_cheers:
same results when i did it, i'd say it works pretty good if your motor actually has crap built up in it otherwise i think its 5 min of extra wear since it thins the oil.. . . glad it went well for you!
