- Nov 15, 2009
SinnTax, i used that gunk high mileage motor flush stuff before my last oil change and it seemed to work well. I had some valvetrain noise at around 3k that i would guess was due to a sticky lifter or something similar, anyway this has disappeared since i used the motor flush. The gunk high mileage motor flush looks and smells like diesel and i did quite a bit of research before using it, all of which suggested it is similar or performs the same function as diesel. so anyway, pour it into cold engine, idle for five min, do not drive, cut engine, change oil. your oil will run out like water, it was noticeably thinner than normal as a result of the motor flush, also everything will smell like the stuff. The oil that came out was dirtier than normal, and like i said my problem went away, i would recommend this to be used with discretion. i think its good if you have a problem, but causes unnecessary wear if you dont.
