Slow-ish wipers on high speed.
whisperer
Bend OR / Hilo HI
My wipers have always run slow since I got this truck, at least compared to my other RBV and FS trucks. The fast speed is about the same as the slow on everything else. All the speeds DO work, it doesn't seem to be a control or switch problem. I pulled the gearbox cover on the motor and the grease and gears look fine and clean, and the motor doesn't have any visible issues - except it doesn't drive the linkage very fast.
Is this "normal" or should I replace the motor? Any other ideas?
