slave questions
--weezl--
June 2011 OTOTM Winner
Law Enforcement
OTOTM Winner
TRS Banner 2012-2015
hell
ok, so i have had my slave replaced, they did the clutch disks at the same time, in may, they replace the clutch pack again, but NOT the slave (even though it was a slave problem, and i'm 100% sure of it) so problem is back, clutch is fine i'm sure, i'm just going to replace the slave... (clutch disks are only a month old)
ordering from rock auto, looking at the sashs probably... there's one with and one without the release bearing, do i need that bearing?
07 fx4 level II supercab longbox 4.0L SOHC
not if the release bearing is as new as the clutch disc. it should come with the clutch kit and they should have installed it.
you would think so, but i don't recall if they did or not...
I don't know what your original problem was.
The problem on my system was no (or very little at times) clutch release. I replaced the clutch slave cylinder on mine. The problem lessened, but didn't go away. Replaced the clutch master, problem solved. Something to think about.
my problem is that the clutch originally made a squeeking noise when pushing the clutch in at higher RPM, kinda like pulling a straw through a slurpee lid or fountain drink lid...
so i went in, got them to take a look at it my whole "clutch gearset" was needing to be replaced, luckly i had a clutch warranty written into my bill of sale, so they covered it 100%, they replaced everything! clutch, bearings, slave... everything!
fast forward 8 months, i'm in the bush 4x4ing, in 4 low, when it gets hot, then sits in neutral, i can't get it into 1st gear... have to shut the motor off to get it into 1st gear...
take it into another dealership, he calls me a liar, tells me there's nothing wrong, i go complain to the GM, they end up "fixing it" by replacing my 1-2 syncro, but it doesn't fix it... same problem persists... (this is in december)
fast forward to may of this year, i take it into a 3rd dealership, because the first 2 are dicking me around... the service manager goes for a drive with me, and says yeah, there's definitely something wrong, and when it's in 4 low, from neutral, i go to put it into 1st, the truck rolls forward as it goes into gear... but he says that he doesn't want to get involved in my truck because there's already 2 dealerships involved in fixing it improperly...
so i take it back to the first dealership, they pull the transmission, and the clutch has inner wear, consistent with riding the clutch, they tell me right off the bat that it's not covered by the warranty (ford gives 1 year 20,000 km warranty on all clutches replaced, though the dealership used a sashs clutch, they will honor the warranty) i tell them that's impossible, i do NOT ride the clutch, they also tell me there's hot spots on the flywheel... they call me back about an hour later and tell me it's a manufacturing defect, and that the clutch wasn't fully disengaging at a stop, causing it to ride... this also explains the rolling forward... i tell them it's the slave, they claim it's not, and it's the clutch plate, they replace the clutch, but not the slave... and now the problem is back (i haven't really gotten the transmission hot since then, other than sunday)
it also releases fairly high... so if i touch the clutch pedal, the clutch slips... i've NEVER had the clutch slip on me with the clutch fully out though
