MXHowes
- Nov 27, 2007
'96 4.0 5-speed
My truck was getting hard to shift/get into gear. I can bleed some air out of the slave cylinder and the clutch worked fine for about two days then slowly got harder to shift (peddle goes down further before clutch disengages). I can bleed air out of the line every two days, just a small amount that comes out on the first bleed stroke then the clutch works OK for a day or so. It doesn't leak a drop between bleedings..... how is air getting into the slave?
Jim
Jim
