ATV24/7
- Sep 3, 2009
so a while back on a random cold day i went to start my 00 and there was no clutch pedal. i got home filled the res. and pumped the pedel. the normal pressure and feeling came back. no problem. now last nite the 96 did the same thing? where could it be leaking from? or whats causing this. i have never had anymore problems out of my 00. yes when its cold its a lil different but i understand they are all like that cold. after reading up on it. everyone says it is leaking out of the slave cylinder seals. the cold causing them to shrink. is this true? should i check or replace anything else?
thanks in advance
thanks in advance
