slave cylinder leaking
B II Ian
hey guys, ive just replaced my slave cylinder, master and the hydraulic line (bought everything motercraft) my truck is a 1995 ford explorer 4x4 5 speed
when i got my trany back in the first thing i did was click the hose into the slave cylinder, while i was puting the starter in, i noticed that where the hose clips into the slave cylinder is leaking, so i took the line out and cleaned everything realy good again with brake clean and a air blower, put some multie purpose greese around the o ring and pushed the fitting back into the slave cylinder.
everything seemed mint nothing was leaking until i went to bleed the slave cylinder and brake fluid was squirting everywhere, ive taken the line out of the slave cylinder multiple times cleaning it and such and still leaks.
anyways my question is has any of you dealt with this before? I drive my vehicle everyday and need to get this fixed asap so any info would be sweet
Thanx in advanced Ian
