skyjacker drop bracket?
farmer
Rochester, NH
Mix of 78-96
13ish
39.5x15.5
This may be a dumb question but I'm putting a 6" Skyjacker in my 94 and the pivot bracket for the drivers side beam has a couple extra holes for reenforcement.. How the hell am I supposed to drill these out? The bracket is inside the framerail so theres no room to get a drill in there. I searched and found nothing on this, am I the only one who's had this problem?
I assume you're referring to the holes that need to be drilled into the frontside of the engine crossmember?
Do you have a right-angle drill? If not, maybe you can make a template for it so you can drill it from the front (if it's a class II kit you're putting on, then that little support piece that goes there can serve as your template). Fortunately it's not going to be the end of the world if you're off by up to a ¼ inch or so, you'll just need to ream it out some with the drill to align the holes.
Yeah that's the bracket. I figured I would need a right angle drill, I'll see what I can find. Thanks
