- Apr 5, 2009
- Automatic
coming from my left front wheel area when coming to a stop or slowing down and also when turning the wheel LEFT at slow speeds.
I can speed up to like 30 mph then get on the breaks and usually around 5 to 10 mph I will hear it and feel it in the floor board, I can then speed up and do the same thing again and it will happen again just like before.
What say you? THANKS!!!!
BTW, I looked under the front end and do not see anything OBVIOUS at all that could be the culprit.
EDIT: I forgot to mention that I noticed that my front tires are wearing / cupping, on the inside of each tire, identical on each side.
I have never had an issue with abnormal wear on my front tires until recently. Besides the obvious assumption of needing an alignment,what could be causing this CUPPING of the inside tires along with the CLICK/POP sound.
