Single click/clunk when hitting brake pedal?
askthemasses
Seattle, WA
Just started hearing a single click like noise when applying brakes. Sounds almost like it's coming from the pedal? I checked the calipers- they're snug (though we're loose last week but I retightened them). Just redid the calipers pads, rotors and had the brakes bled. Any thoughts on what this could be?
Happens when car is in any gear. When parked and I hit the brakes a lot to try and find the sound the brake pedal stiffens up (almost like a steering wheel locking) and doesn't go down far enough for me to hear the sound.
Try backing up and going forward and hit the brakes, see if its a front end component that is loose.
Click from pedal area could be the brake switch
Got down by the pedal- it's almost like the noise is when I hit the pedal because it moves to the side ever so slightly. Could recreate the sound by using my hand to tap the pedal to the right or left very gently and lightly.
Pedal bushing. Keep on truckin.
Agreed : If it's not the calipers shifting when pressure is applied ( you said they were loose but you fixed it), and the sound is from the pedal, nothing to worry about. Unless it's annoying and you cant stand the sound, turn your radio up right before you hit the breaks hahaha.:D
