hkerekes
- Mar 6, 2010
I bought an 89 2wd extended cab for cheap. The previous owner ( redneck ) "fixed" alot of issues that I knew I would had to correct.
One is the fuel pump wiring. He has hotwired the fuel pump from the fuse box.
The factory wiring at the pump only has 6 ish volts. I tried looking for the inertia switch and I think it is gone and he just connected the wires. There is an orange / black stripe and a pink / black stripe connected in the footwell. I guess that would be the inertia switch wires.
The fuel circuit goes from the ecu - relay - inertia - fuel pump correct?
The truck doesnt run smooth and really bogs down when it gets hot. I think the fuel pump is overheating and causing issues.
I guess I need to find the inertia switch or lack of and test for 12v there. Then once i figure that out i can trace the wires to the pump and find out why the voltage is low on the factory wires.
There is no inertia switch and the local parts stores dont carry one. Where other than the dealer and ebay do people get them?
http://cgi.ebay.com/ebaymotors/FORD...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories That should work correct?
