Side mirrors
dvdswan
Seattle, WA
3.0 V6
Keep your mind like an umbrella, it only works if its open... Continually learning.
Did Ford ever put larger folding mirrors from the factory. Similar to this...
56017
Look like full size truck mirrors to me. Hmmm......
I'm trying to find some that are actual factory and not some cheap copy. I see a lot of pictures of Rangers with them, but it seems rockauto and others don't show them.
They're called "Bright low-mount swingaway mirrors" in the Ford brochures up through 1992. So yes, they were a factory item.
They're pretty durable (unlike the little flag-style mirrors), there's good chance you can find a decent set at a wrecking yard.
That's what I'm hoping for. Thank you.
dvdswan,
They were stock on my 87 BII; ironically, people always ask me where I sourced the Sport mirrors on the Ranger 🧐
Had to paint them black?
Ok, so is there an interior door brace/bracket for the lower or upper arm on the mirror for support?
dvdswan,
There is no interior brace, it very much just bolts on. I don't remember it the screw bosses are reinforced inside.
Not really a "brace" but the skin has a reinforcement inside.
Looking at the conditions of some of the doors, I would reinforce them when mounting the mirrors. I would recommend using threaded inserts as well instead of a bolt and nut.
So which would be better for the mirrors?
jack nuts with a plate or 12g sheet
56138
or rivet nuts in a brace/bracket about 1/8" x 1" x 6-8"
56139
I suppose I would know better once I find a set of mirrors though.
I would make a plate that covers the same footprint as the mirror base on the outside of the door and put that inside the door. Then just use bolts/nuts or whatever.
Thank you for all the info.
Exactly how I did it on my first gen... except I tack welded nuts to the flat stock and it was a bit bigger then the mirror base.
It's been years since I looked at mine. Went and checked out my parts doors and there is a brace that runs top to bottom.
Starts at the top mirror bolts
Bottom mirror bracket bolts
Possibly riveted at the bottom.
