Danger FX4 Ranger
1970 Mustang with a 1100 Cu in Ford gas burner from a Sherman tank (Ford GAA motor)
http://forums.streetfire.net/showthread.php?t=15813 That motor swap took some work.
Did Sherman tanks have such advance engines back in the 1940's? Cast aluminum blocks & DOHC?
Put still, 1100cc.A bit overkill in the displacement. It would only need two gears. Slow and hual-butt.
That would be 1100 cI. Inch. "Slow" gear goes 0-60 in negative 4 seconds. Put it in "Haul-Butt" gear and you see yourself pass yourself several times.
My bad. Quite a difference between "cc" & "ci".
Its 11:12pm, caffine still refuses sleep time.
