Shuddering When Pulling Away
stableboy
Stanfordville, NY
Hi, need help diagnosing a front end vibration. 2003 FX4 Off Road with automatic
Symptoms: If I accelerate from a stop while turning right or left I get a noticeable shuddering/vibration that continues up to maybe 15 mph. Once rolling it is perfectly smooth in straight line or turns. Replaced front u-joint on the rear driveshaft, both hub bearings, both cv shafts and both lower ball joints - uppers OK. Now it's as bad or worse. I'm running out of things to replace. Please don't tell me it's the front diff! Thanks!
Shuddering in the steering wheel? The whole truck?
How about taking off on a hill, and not turning? If it did it in that scenario, that would point to possibly a engine problem or a transmission problem.
