show off your 1998
high_tech_redneck
green river wyoming
1998
id like to see some 98 rangers extended cab with a lil bit lift and 33 bigger is fine to im just tryin to get an idea of what it will look like
3 inch suspension lift, 32/11.5 pro comp wheels/tires.
this was before my 01-03 headlight swap
this is after
my truck has a 3" BL and explorer springs and a t-bar crank for a total of about 5.5" of lift on 33's
Torsion keys u mean?
Yes torsion key's. there cranked all the way down, cv's bind too much when cranked up. belltech 6400 shackles in the rear. measured from flat concrete to bottom of the frame before and after. It was about 3 inches gained maybe more in the back. About to be putting in new leaf's too. so I gotta do something to raise the front. thinking maybe a mild sas. but not sure. The direction for this truck has changed. Turning it into a long range off-trail camping rig. might go with rcd lift brackets and air shocks. we'll see. Its still my daily driver. So until I have a new DD nothing major will be done.
