should I throw some engine oil into the cylinder
whitebroncoii87
Hi, I have the heads off, before putting them back, should I pour some engine oil into the cylinders? It'll probably sit on top of the pistons and get them all oily.. Is that good? Thank you!
You are allowed to ask more than one question per thread.
Don't use engine oil. It will foul the plugs almost immediately. I use WD-40 or PB blaster. Something that is fairly flammable.
