R***A**N**G**E***R
- Oct 3, 2009
- Automatic
I have been babying a seeping/leaking head gasket for about a year and a half now, I have kept it under control SO FAR by using additives, anyways coincidentally I also have had a thermostat stuck OPEN for about the same time my question is if I replace the thermostat will I be pushing my luck with the bad head gasket because of more pressure???? the reason I want to put in a new thermostat is because in the winter the heat is not very good since it is stuck OPEN it never really gets a chance to heat up and I can't utilize my heater to my comfort level.
The reason I have not FIXED the head gasket is because the engine has 253,000 miles on it and it doesn't make good money sense to have it fixed when who knows when my engine is finally going to go I mean 253,000 miles is a shit load of miles.
I can get a new engine from ford for I think 2,200 plus labor and a warranty I refuse to take my chances with a so called low mileage engine from some junk yard NOOOOOOOOOOOOO THANKSSSSSSSSSSSSSSS!!
