NetBSD
- Sep 4, 2008
i dunno how usefull this is for some of you but i got sick of my steering wheel being up in my face in my 89 ranger reg cab so i modified it a little.....
remove the steering colum from the truck and seperate the 2 pieces like shown here
now the piece that goes thru the firewall is the one we want to cut, i only cut a little bit so i didnt have to modify the shaft at all. heres what it looks like after being cut
you can see how much i took off in this pic better
now this is the tricky part, put the 2 pieces back together and you will quickly notice that bolts dont line up for mounting the colum to the dash, so i grabbed the drill and rat tail file and went to work.
i still need to make a plate to go down to the other nuts welded on the colum, but you get the idea
and a look from the side after it was all reinstalled and i greased everything
also as a added bonus ill show you how to service the steering colum bearing
grab a 13/16th socket and use it to knock out the white snap ring and bearing, clean in gas and pack with fresh grease, no more squeeking when im turning
