nvcook42
- May 1, 2014
A couple of days ago my truck all of a sudden would start. I quickly discovered that it was because the clutch pedal switch was acting up. If I pushed the clutch all the way down it wouldn't start. If I let the clutch up about and 2 inches it would start great. So I figured I would need to replace it soon but in the meantime I could keep going along fine. Then the weirdest thing happened. I went to start it and it did but the starter motor didn't turn off. So I turned off the ignition but the starter motor was still cranking. I quickly popped the hood and disconnected the battery. Now if I connect the battery at all even with the ignition off the starter motor kicks in. Seems like the clutch switch has shorted out on me.
I am a noob at this sort of thing so I went looking for the part to replace but can't seem to find it. My truck is a 1987 Ford Ranger 2.9L V6. Can anyone point me at the correct part that could be shorting the starter motor from the clutch. Thanks.
