Shock Question
wizkid00104
West Newton/Penn Hills, PA
I am putting in a new axle and it needs shock mounts put on. I was going to use these: http://www.ruffstuffspecialties.com/catalog/paired-bracket-p-43.html
The problem is that they mount 90 degrees from the stock mounts. I mean that the bolt that goes through perpendicular to the axle instead of parallel. Can this be done? Should it be done?
