Shock Extensions?
JDanger
I did a torsion crank on my 03 FX4. I went up about 1 3/4" and would like to find some shock extensions. My ride has suffered and it does feel like the shocks are at the max extension. Does anyone make a 2" extension?
i've seen them at pepboys and other parts stores before, you could also probably find them cheaper online.
I'd just buy new shocks and sell your old ones locally.
Never use shock extensions. I used them, it wasn't a day before I bent the tops of the shocks. Luckily Autozone warrants their stuff and I upgraded to longer shocks.
Turning up the torsion bars effectively makes them stiffer. You do not need shock extensions.
It also makes the shock bottom out on extension when you hit a low area or the tire drops off in a hole cuz you have taken the shock out of its "Working" range. I have checked at the local NAPA but nada. Anybody?
