Shock absorber mounted to engine
C.Fuller305
South Carolina
I have a 1994 ford ranger 4.0 v6 and I’m in the process of doing a top end rebuild on the motor. I noticed there is a small shock absorber attached to one side of the motor. I have never seen it before and I don’t know if I should replace it. If I need to what is it called (picture shows the shock)
It's a vibration damper
Most folks just take them off
I have the same motor. Took mine off several months ago. Haven't missed it although I may replace it one day if I get bored.
+1 ^^^^ on all the above
When the 4.0l OHV was first used in the 1990 Rangers engineers thought a damper would be needed because of the higher torque of the 4.0l, so added the small shock absorber/dampener
It was eventually dropped
I thought at one point after removing it, that it might be useful as a damper on start-up to absorb some of the initial torque.
The 428 in the Mercury Montcalm we picked up had a chain to limit engine rotation when you stomped on it!
The rubber in engine mounts isn't very strong in tension and once separated the engine gets pretty jumpy.
I use solid mounts in my race car. I don't care if it vibrates the car. I just don't want to waste torque twisting the rubber motor mounts and don't want weight shifting around in the corners. Some racers also tie in a bar up higher on the engine to the chassis to reduce movement even more.
