Shiftster + 4WD lights
94firstranger
TN
I think I am going to get a Shiftster for my '94 4x4. The motor makes me nervous and this will hold me over until I swap in an actual 1354M. Looks like Advanced Adapters sells them.
Question for those with one - if I use the Shiftster to engage 4H or 4L, will the dash lights come on, or is that dictated by the motor?
Thanks!
The dash lights will not work. Since the motor contains the contacts for position indication and you will be removing the motor, then, neither the 4x4 module nor the dash lights will know what position the transfer case is in.
This message composed solely of recycled electrons. Go green!
Got it, thanks for the response. It is my understanding that the t-case module is separate from the PCM, so aside from lights, I won't see any odd behavior, right? I have manual hubs, so I can lock.unlock by hand.
Thanks!
It shouldn't affect anything but your 4x4 system. I would recommend pulling the fuse for the 4x4 module. Also, after removing the motor, I would try to wrap and seal the electrical connector so it doesn't get full of dirt and corrosion while hanging down there near all sorts of dirt/ water/ road salt / etc. Secure it somewhere out if the way.
Thanks again for the response and good call on the fuse.
One more question - I see the instructions on AA's site state to shift to neutral, turn off engine, rotate Shiftster to desired position, then, start engine and shift into drive.
I have an automatic (for now). With the motor, I usually shift to N, engage 4x4, get out and lock hubs, shift into drive and go. Is the instruction to turn off the engine a safety precaution, or is it required when using the Shiftster?
Thanks!
Purely safety related. I'm sure you don't really want to crawl under your running truck and fiddle with something that engages engine movement to driveshafts and axles. There are no switches or wires on the shiftster. It is purely manual and purely mechanical. It does not interact with your transmission or ECU in any way. All safety measures are your brains responsibility. If you must mess with it on unlevel or uneven ground, be sure to chock the wheels to prevent the vehicle from moving.
Thanks!
This is good to know! Possibly the guy that builds them finds it safer to Market them through a company like Advanced adapters instead of himself.
I had a thread about using a flexible shaft and or using the shiftster as part of the idea so a person doesn't have to crawl under the truck,
So far the only thing I've done in this area is to determine that the gear from the old electric shift motor can have a set screw drilled into its hub and mounted on the shaft of the transfer case. haven't figured out the indexing and or flexible shaft part yet LOL
