shifter ????
tmaxxman
PA
GOT A ??? CAN I PUT THIS SHIFTER ON MY TRANY :icon_confused:
[/IMG]
I HAVE THIS ON MINE NOW AND I DONT LIKE THE LOOK OF IT :annoyed:
[/IMG]
My first instinct is to say yes
I'm assuming the donor tranny is an FM145 or FM146? and the reciever is a Toyo Kogyo? If so the swap should work, i think the ends are the same. And the Caps lock isn't necessary.
im thinking no, but maybe you could change the whole trans out for a M5OD and then you could use that M5OD shifter.
a '88 would have had the "tall boot" shifter so someone swapped a older trans in, I don't think fm145 and fm146 shifters swap but could be wrong, can allways cut the sticks off both and weld the fm146/mazda style onto yours
