1990RangerS
- Oct 10, 2009
While in the process of replacing my rear main seal, when I removed the shifter assembly from the top of the transmission I think that I may not have shifted it into neutral first. It was up on ramps so I had it in reverse to hold it, and it now appears that it may be stuck in reverse. While the shifter goes into the neutral position, I'm unable to shift into any gear. Is there some way to shift the transmission into neutral without having the shifter inside the transmission? Anybody got any ideas?
