MJ'sBlkBII
Hope this is in the right section...
I finally got hold of a shifter for my swap. It is from a '90 Aerostar. It is neat, it is angled more tword the driver hip for more of a "sportsy" feel. The only problem is that I can't get the stick to separate from the stub. Any ideas how to do this without damage? I was able to remove the nut, however the stud stayed in place. The bushing is completely usless. So is the small metal...spacer...washer...thin piece of metal between the bushing and the pivot ball. I thought about grooving one end and then using a big screw driver than just replacing it with a new bolt. Thanks, MJ
