Shift Light.
Schwinnstingray1964
How do i install a shift light.
It appears that my radio is to loud to drive stick...
No clue. Try turning down the radio or shift by tach...
You need to get a better feel for your truck if you need a light to tell you when to shift...
ummm...if you need a light, you don't know the truck well enough....hell any manual vehicle for that matter.....
Haha, Well ive only been driving it for a little while now.
No tach, but i guess ill just learn it better.
in a 92 you should be able to buy a cluster with a tack in it and just swap clusters. with small torques bits pull the clear cover off and gently pull out the spedo set up from your current cluster and replace it in the tach cluster so you keep the same milage. then reinstal the tach cluster. the connections are the same on both clusters. its an hour swap at the most two if you count going to the bone yard and pulling the cluster. it cost me 15 for the cluster at a pull-a-part and they seel them for 30-40 on ebay.
i judge by how the truck pulls, like the torque/power i guess, when she speeds up alot, shift.
Or pick up a cheapo walmart coil tach
ya but for about the same price i would want something to look factory
A walmart tach is $20. If you can get a complete cluster for that I'd be impressed. Most yards around here want $50 for a cluster.
