I was told at a spring shop that the shackle bushing for a 2.5" wide spring will actually measure 3" wide. The belltech chevy/ford 2" drop/lift shackle will give you about 1 1/4" lift by my measuring. Approximately 1/2 advertised because I measure at the spring, not the shackle. I held my old shackle up to the belltech 6400 chevy 2" drop and the bell was about 2 1/2" longer [center to center on bolt holes].
Richard
you lost me on most of that... lol, you also realize that the difference in length between the two shackles is NOT the same as how much your truck is going to be lifted, right? the number you get, (if ford shackle is 2" and chevy is 3 1/2", your difference is 1 1/2") 1 1/2 is not how much your truck is going to be lifted, it's all due to angles and triangulation, it's going to be closer to half that... so 3/4" or based on what you said, it would be closer to 5/8ths taller
the spring shop you talked to, did they say the bushing width on the chevy and the ford are the same?
*edit* i re-read what you said, i mis interpreted you, i thought you were measuring from the end of the spring, when you SHOULD measure at where the axle bolts to the spring
what's the actual measurements on your stock shackle, bushing width, spring end width, and length, if you don't mind please
that way i can go in and grab a chevy drop shackle at the parts store and see if they will work better than the belltech (cost wise)
also, does anyone know if these shackles have changed on the ranger between when always floored's truck was built and mine was?
