shackle mounts
mmterrill
getting ready to replace my rear shackle mounts but first i was wanting to know if there are any tricks on getting the bolt out of the spring if it seized in? any ideas would be great.
Grinder with a cutoff disc (about the only thing that has ever worked for me. The hardened bushing sleeve will do nothing but round teeth off hacksaw or Sawzall blades).
If you can get the head of the bolt off you can then use washers/nuts behind the nut to draw out the body of the bolt. use never-sieze so you don't gall the threads too much.
