Several issues with truck-need help!
Gho$t
My little 94 ranger I believe may be on the verge of dieing.
The first issue with the truck is that it has a starting issue that I guess is rare.
When I try to turn the engine on, sometimes but not all the time, the truck will turn over but will take around 15 seconds to even get started. I've changed out the starter along with its solenoid, The starter relay solenoid up near the firewall and just about anything that has to do with the starter.
The next problem is that when I can actually get the truck started, or I come to a stop, or press the clutch in. My engine doesn't idle correctly, it idles extremely high and I've had a few instances where the truck has idled high then idled extremely low and shutdown.
I can give more information as the thread goes along because I really need a few specifics on what it could possibly be. thank you :)
Could it possibly be my Idle Air Control Valve?
IAC was my first thought for the idle issues. Possibly the hard starts too but I'd suspect fuel pump or pressure. Not sure if '94 has it but another possibility is cam sensor. Clean or replace the IAC & see if it gets better.
