sledneck07
- Dec 13, 2009
Disclaimer This is what my 1991 4.0l runs at your engine my be different depanding upon driving habbits, mileage and verious other factors. Also this info is accurte for all gas 1990 to 1995 RBV to the best of my knowledge.
EXPLAINATION I've noticed alot of posts about what the engine temp and oil psi should be at and replys turning into a run around and bi*ch fest. I always put a set of mechanical gauges in when i get a different truck and think they are worth every penny as the factory ones are inaccurate (hence dummy gauge (I highly recomend picking up a set (I use sun pro gauges and never had a problem))). Even though it may in the normal range your readings could be way high or low.
FACTS
ENGINE TEMP Your engine is the most efficinet at 210* as that is what it is built to run at. Your temp reading will very where your sending unit is located. the closer to the radiator outlet the cooler the reading because of the incomming water was cooled by the radiator. The closer to the inlet the warmer the reading will be, because all that coolant just ran through the heads and block and is headed into the radiator to be cooled.
-Your coolant temp will go up during accerlation (my 4.0l usally goes to 230* other engines my very from that) due to the added heat being produced. Once your going a steady speed you should be running about 190*-210*.
OIL PRESSURE Your engine oil press. Should run at 40-60 PSI at 2000 RPM. When your engine is cold it will run at a higher oil pressure because the oil is cool and will be thicker than it is warm, and the pressure will be lower when your engine is warm. Im usally at 45 to 50 PSI with a warm engine and steady RPM. At idle with a warm engine your pressure my drop down to 20 PSI but that is fine, but if your running down the highway and your pressure drops below 40 PSI you have a problem. A spun bering, bad bering and something else could be the reason for poor pressure (but before jumping into and answer and digging in go and get another guage and test it ( a $20 repair is better than a $200+ repair and end up having a bad oil pressure))
FACTS
