- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
98-11 largest engine bay. I don't think it's so much a matter of it being physically larger, as it was just being laid out such that it has more room to work with. Core support and firewall are in the same locations, and the frame rails and cabs are essentially are the same widths. Things like the airboxes and frame crossmembers changes shapes/locations.
The 98-11 is practically the same as 96-01 Explorer that came with the 5.0L V8, that's why the swap goes so well in those. Explorer changed again getting more roon in 2002 (when it got the 4.6L), but the Ranger remained the same through 2011.
You do realize that the truck and/or axle needs modification to install an Explorer axle into any Ranger right? In addition the widths are different and the Explorer axle is wider than all of them. I'm not going into all of it here, its is all covered in detail in past threads and in the tech library. Being very basic the leaf spring perches are the same width on the Explorer and Rangers, so the Explorer axle will "fit" any Ranger with the right modifications.
That said, a Dana 80 (F-350) or a Chevy 14 bolt axle will "fit" too with the right modifications. Not a many more modifications either (realtively speaking), but they'll be way too wide unless you're going for a full width SAS.
