lneidlinger
Hello all, long time lurker, first time poster.
My friend is looking at getting a bronco II. We found one that the body is in real good condition, paint is a bit faded, but everything is there. It's got a 2.8 in it, and its apparently seized up. The reason why its seized up is that its been sitting for about 7 or 8 years.
Everything is there on the motor, it all looks clean. The carb looks like it's in good condition, and everything still moves freely on it. I assume if we can get it for a real good deal, it might be worth a shot to take the plugs out and spray some aerokroil down in there and see if she will turn over. Then of course check the oil, check if the starter will turn it over, check for spark and gas then see if she will fire. My question is, what are the possible ramifications down the road of how the engine will hold up after being seized? Also, how do you guys think the water pump/alternator/power steering pump are after all this time? It also has a A4LD auto (with an added trans cooler) and it's 4WD, so how do you guys think those are holding up, seized too or what?
Thanks
Thanks
