see if they do some damage :)
stevealvey24
Pretty much stole these for 60 bucks. 15#ers. Gunna install them, change my oil and filter tomorrow. Be back with the update on how they work :)
Man!
you could blast paint off a chassis with those squirters!!!!!!!!!!!!!
:yahoo:
I thought the same thing. But apperntly they use a disc in the injectors housing.
Not going to do anything at all except what they've already done--remove $60 from you. The original injectors in your engine were good for 50 more horsepower, if you had a way to provide the air they needed. You don't have a turbocharged diesel which has all of this extra air available all of the time and you can just squirt in more fuel to make power. the computer just needs injectors that will provide enough fuel for the air it sees.
Exactly. That's why you see all those programmers for diesels because they cram fuel into the engine.
The only gain I see is if your injectors were dirty.
Kind of agree with the two above me. Not to sound rude, but you wasted $60 unless you are planning major upgrades for your engine.
Just installed them and get a 2.9 crankin' I'm here to tell ya. But.I.got a lot of air in the lines that needs to be worked out.
