Secured weight over the rear axle options
Wicked13
What is your set up for keeping weight over the rear axle? I'm trying to come up with a way to keep weight over the rear axle and keep the bed usable. Something low profile and secure in case I'm in an accident. I just took out my sand bags (which weren't tied down, I had a 2x4 frame that kept it in place...) and I forgot how bad it bounces around with no weight.
there is a thing u can buy online and u fill it with sand and it is mostly flat but it is built to last so u can stack stuff on top of it u can slide heavy fruniture over it so it is trally durable
I like the idea of a filled liner...I have used several things but one of the best things is 25 lb weights...they can be easily secured with rope or even a barbell...didn't use anything this year other than snow...and I load stuff in the bed all the time...just shovel out what you don't need to make room...shovel it back in if you need some traction...
Can you direct me to a brand or a place that sells this?
yup that is one of them^^^^ those work great to idk where i saw the ones with sand but they are pretty much the same
Looks great! I think I'm going to go with the 300lb model.
I used 100 lb suit case weights from one our tractors in my old 2wd regular cab. The super cab seems to handle perfect with no weights though.
Sent from my C771 using Tapatalk 2
