- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
99 Ranger 4.0L that has been engine swapped with a 2000 Explorer 5.0L
I stalling a wideband O2 sensor for tuning and need to find a wire/circuit to tap into for powerering it. The instructions include the following.
So I need to locate a wire that is hot in engine run only. This does not need to power the wideband itself, I can use a relay and just have this wire triggering the relay.
Any ideas?
Do not install the Lambda Sensor in such a manner that the unit is powered before your engine is running. An engine start can move condensation in your exhaust system to the sensor, if the sensor is already heated this can cause thermal shock and cause the ceramic internals inside the sensor to crack and deform.
While the Lambda Sensor is in an active exhaust stream, it must be controlled by Spartan 3. Carbon from an active exhaust can easily build up on an unpowered sensor and foul it.
Any ideas?
