With respect im going to have to disagree somewhat with MAKG. Yes the released carbon could hurt the exaust more than help, and yes some of the white smoke I was suppose to get is some of the seafoam burning. I did a test on a small flathead cylinder head to test what effects the seafoam had on the carbon. I put the head in an oven for 10 minutes to roughly 250 degrees, poured a small amount of seafoam on it and wait for 10 minutes, and as the engine is suppose to do, blow the mixture off, for this test an air compressor at roughly 25 PSI. The result was about 60-70% of the carbon was removed just with air. Would i say it works? Well I can say it most certainly helped, but it could have some very serious problems for an engine if alot of carbon exists. Their will always be skeptics, sometimes for good reason or just so they wont do it. I put gas in my tank everyweek, I use simple green to clean my house, I use windex to wash my windows, and i use seafoam to clean carbon. All chemicals designed for a certain purpose will often times work, but using the chemical correctly is where the trouble can begin. Thats my 2 cents, worked for me but may not others.
