SCX-10 Bronco
gribly
Maine
This is my second scale crawler project, it's been 10 years since my last one. I think i did pretty good. Originally it was a stock SCX-10 TR that I drove the snot out of all summer. I had worn out almost every joint on it and had to do a complete rebuild, so I decided to stretch the wheelbase and paint up a pro-line 1973 Bronco. Yes, the body is too long and the rear windows look strange, but it climbs better with the longer wheelbase.
That's pretty cool. There's quite a bit of RC Crawlers on here.
Wish I could join the ranks but..I'm just too poor at the moment :D
Less than $300 brand new, very rugged little things. I bought one and a friend bought one last spring. His is mostly untouched, and only has worn out one rear upper joint on the axle and needed the shocks refilled once. The box has enough spare parts with it where all you need is the truck, a battery, and a charger. Oh, and locktite the setscrews on the axles - the universals fall right off the truck until you glue the screws.
AWSOME...
i picked up a Losi mini Rock Crawleri and have maybe 150 into it, got a smoken deal on it at the local rc shop as it was a demo. I got a ton of part's with it and have monkied around with about everything on the dang thing tryin to get the most out of it. i improved the suspension flex by about 65 percent by doing very little. it almost has too much now but for using on couche's and around the yard it does just fine. the only thing i really put any money into was gettin the body and painting it (all of 15 I.I.R.C.) EB's ROCK
even tho mine's not a scale crawler or nothin. the body is acctually for the losi mini T but i made it fit.
Nice flex! Mine doesn't have much articulation right now. The stock shocks are too short to have the body tucked down on the frame like I do. At full compression, there is still 3/4" of shock travel left, and they are pretty much fully extended at ride height, do it has pretty much zero drop-out. I'm going to change that, but first I need a new M5OD for my real truck, mine has loose bearings and worn gears.
if you cant tell by the orange hose on the shock's i did some "fine" tuning to the suspension using some misc. spring's i have about 1/4 travel of droop. with this body i cant really fully tuck the tire's notice the body isnt pinned down. I use the stock body when i run it around at the rc shop and try and compete. the factroy body has been hacked to pieces for clerance. most ppl cut fender's for clerance i had to cut the hood and box off the factory body.
as far as the M5OD hope all goes well for you. it look's like i will be throwin a clutch in mine if i run it in my next truck should hold up to what is left for the B4000
Got my Mazda all fixed up, so I spent some time and money on the Bronco. I went from 1.9 tires to 2.2's, so now it has 4.8" tall tires on it. The math works out to roughly a 44" scale tire, since the body is about 1/9th scale. I also stuck the longest shocks I could find on it, they're just under 6" long. I've got zip-ties as down-travel limiters on the front and rear, and they don't interfere with articulation much and the front one is only there so it doesn't throw the front driveshaft so easy - my driveline angles are absolutely horrid - about 50 degrees on the front transmission u-joint at full droop without the limiter. I'd re-locate the tranny, but the lower suspension links attach to it. I'm working on a fix - I'll probably have to make a drop bracket setup that has integrated suspension mounts, but I need to keep it strong, I run this thing pretty hard. I'm very pleased with how it drives now. I also killed my rock crawling motor - so I went back to stock. The huge jump in power was probably for the best with tires this size. It powers through about any mudhole I can point it at.
you can get them cheap man. i was poor when i bought mine, $165 out the door. i got a job a little while after and i've probably put that much back into it with upgrades.
i want a scaler one day, but it's been months since i've driven my maxstone 10, so i doubt i get one until we have kids.....then i'm gonna have ALL the badass toys, lol
Mine has cost about $800 to build so far - and I have to spend about $300 more. I need cvd's, a better radio, more batteries, and a different motor.
$1100?!?!?!?! DAMN. i'd rather put that into my b2. i could do so freakin much with 1100 bucks.
it's still badass though, those things can do stuff my b2 will NEVER be able to do
It's not all in the truck. I have a killer charging/battery cycling setup, and I run batteries that are $50 a pop in this thing. Some parts have been removed and replaced with more durable pieces, and I've been through a few sets of shocks and springs to find out what works best.
This also isn't really a scale crawler anymore. More of just a scale truck, it doesn't climb near-vertical like it used to, it tips over now. I've built it to take it on hikes with me - I have trouble walking, and this takes my mind off of my foot while I walk long distances. It's not just a toy.
ive got around 1200 in my 4x4 truck, it can get rediculous!! :bawling:
Well, I blew apart both the front and rear driveshafts tonight. Going to try and make a set of my own tonight, if that fails, I'll just buy some steel ones. I wanna drive it tomorrow though, lol. I'll post pics later of what I come up with, need something that'll survive the crazy driveline angle I have. I might lower it, too.
