scratching my head
masracer
Charleston WV
this all started with a dead battery . charged battery . when truck started ran rough wouldnt idle stalled . the truck is a 94 ranger splash 3.0 5 speed . replaced battery always starts n morning or after sitting if it has stalled and wouldnt restart when driving check engine light comes on and off but has no bearing on when it stalls. every now and then get 111 code as im driving with nothing connected to test port. truck will always bump start no problem have replaced battery tps plugs wires button cap fuel pump fuel filter ignition module ignition coil have cleaned iac cleaned maf and o2 sensors
Lack of punctuation makes things very difficult to understand. I tried to decipher your post until my head hurt, then I gave up.
If it just randomly dies, you might be loosing connection to the battery, Check all the cables , positive & ground, sounds like your dropping the 12v, somewhere maybe power to the ignition would be something to check as well. Electrical gremlins are hard to find.
JP02XLT
not loosing power from battery . stall and restart problem i believe are the result of the same condition . when it wont restart strong odor of fuel . fuel pressure in range have checked injector wiring with noid lights also shot of ether didnt help . spark is also good just wont restart with dtarter unless it has sat for 5 to 20 minutes but will always bump start
You need to check the spark & fuel as soon as it dies, there is also a chance that some electrical component is heating up, like a coil pack or even the ECU.
JP02XLT
