Nathan123
- Sep 6, 2009
- Automatic
I've been reading all the posts about swapping transmissions and with spring break coming up, I hope to get to the yard and pull everything I'll need. I just have a few questions on compatibility.
If I get the 4.0 liter trans from a 2nd gen ranger, will the pedals and bracket work?
If I get the 4.0 liter trans from an old explorer, will the pedals and bracket work?
Obviously pedals out of a bii will fit, but will they work with the master for the 4.0 trans?
I plan on getting the trans, block plate, clutch hydraulic line, and reservoir from the yard, and buying the rest new. I know I need the slave for the donor truck, but do I get a master for the donor truck and will it fit into my bronco ii's hole? Finally, there is is some disagreement in other threads about the timing/computer. Will the auto computer turn on the check engine light, or will it just throw codes? Why would timing be different, I thought it was 10 degrees on all rangers/bii's?
