- Apr 13, 2008
- Fort Lauderdale
- State - Country
- FL - USA
- Drive
- 2WD
- 3.0 V6
- Tire Size
- P235/75R15
- My credo
- A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
It started with the (R)ABS light in this thread:
http://www.therangerstation.com/forums/showthread.php?t=53466
NOW, in addition to the 'ABS' light coming on more frequently, the (parking) 'BRAKE' light makes an intermittent appearance, and SCARIEST of all, the '4WD HIGH' *and* the '4WD LOW' indicator lights come on together, and are also part of the "cycle"... i.e. it will sometimes run in a sequence: ABS-then-BRAKE-then-both 4WD lights... lather, rinse, repeat.
It's as if it's pumping out an OBD-II code via the indicator lights... what gives?
Won't have access to a really good scanner 'til Sunday...
... thanks in advance!
