- Apr 13, 2008
- Fort Lauderdale
- State - Country
- FL - USA
- Other
- FLEX-fuel, baby!
- Drive
- 4WD
- 3.0 V6
- Total Lift
- 0" bone stock
- Tire Size
- P235/75R15
- My credo
- A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
It started with the (R)ABS light in this thread:
http://www.therangerstation.com/forums/showthread.php?t=53466
NOW, in addition to the 'ABS' light coming on more frequently, the (parking) 'BRAKE' light makes an intermittent appearance, and SCARIEST of all, the '4WD HIGH' *and* the '4WD LOW' indicator lights come on together, and are also part of the "cycle"... i.e. it will sometimes run in a sequence: ABS-then-BRAKE-then-both 4WD lights... lather, rinse, repeat.
It's as if it's pumping out an OBD-II code via the indicator lights... what gives?
Won't have access to a really good scanner 'til Sunday...
... thanks in advance!
Couple oz. of the clear stuff cured both the ABS and BRAKE lights coming on... not sure what "cured" the weird 4WD HI & 4WD LO thingy...
