SAS using dana 30 from jeep yj
i have a built up jeep yj doner vehicle " complete vehicle" jumped time and suffered catastrophic engine failure. the jeep has nearly no usable body panels due to rust. it isn't worth fixing anymore.
so
i am buying a 2wd ranger from my employer for 1,000 bucks
runs great i drive it every day. its a 2005 with 55,000 miles.... you see my motivation? they are getting all new trucks and offering to let their current drivers buy them.
anyways i read the (read this first before posting) post...
i did as instructed and found the FAQ section to be great.
i found out things i never knew! good stuff!
no surprise the dana 30 is a popular swap judging by the info i saw.
but its all coil and 4/3 link stuff... i need leaf spring info.
any help appreciated.
YEP thats the article i read, all coil info... i need info for a leaf spring set up.
just pics for an idea of how to get close is fine....
want to make sure i get the drive line angle right without jacking up my steering.
ive seen pics on line but no good info...
looking for good measurements for a cross member if its needed, and all that.
i intend to use the jeep springs and shackles, i will fab hangers.
the jeep YJ springs are newish and are 2.5 inch lift, i want to run 33's at the largest.
http://www.therangerstation.com/forums/showthread.php?t=154506
http://www.therangerstation.com/forums/showthread.php?t=129530
http://www.therangerstation.com/forums/showthread.php?t=129915
http://www.therangerstation.com/forums/showthread.php?t=119151
http://broncoii.org/forum/index.php?topic=14772.0;wap2
Just keep checking around...I found these in .04 seconds on Google.
CLICK ON THEIR BUILD THREADS IN THE SIGNATURES
The Show Off your Truck Forum on here also has plenty of build threads to sift through. Most are coils, but there are still plenty for leaves leafs.
